LeifA
Apr 20, 2021Apprentice
Orbi RBR 50 - no download speed
Hi! When I installed a new 4G modem/router the function Test my speed in Orbi only tests upload speed, donwload stays at 0.0 (and ping is also 0.0). Everything else seems to work as before and othe...
- Apr 20, 2021
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
LeifA wrote:Hi!
Everything else seems to work as before and other speed tests that use the Orbi WiFi works fine.
Testing with Orbi speedtest gives me a better value for the incoming speed from the modem.
Any suggestions why?
Regards
Leif
LeifA
May 15, 2021Apprentice
Should the Orbi be in AP mode if it is used as the only router after the modem?
Leif
May 15, 2021Guru - Experienced User
IF your modem is in router mode, then Orbi should be in AP mode.
LeifA wrote:Should the Orbi be in AP mode if it is used as the only router after the modem?
Leif
- LeifAMay 16, 2021Apprentice
As far as I know the modem is just a 4G modem, no router function.
I have removed the router thar was installed with the modem because that one could not be put in bridge mode. The ISP who supplies the 4G modem suggested that I connected the Orbi directly to their modem.
Leif
- FURRYe38May 16, 2021Guru - Experienced User
IF the 4G modem doesn't have a built in router, then you should connect the Orbi RBR in router mode to the modem.
LeifA wrote:As far as I know the modem is just a 4G modem, no router function.
Leif
Yes, it is in router mode.
Some answer here suggested AP mode.
Leif
