LeifA
Apr 20, 2021Apprentice
Orbi RBR 50 - no download speed
Hi! When I installed a new 4G modem/router the function Test my speed in Orbi only tests upload speed, donwload stays at 0.0 (and ping is also 0.0). Everything else seems to work as before and othe...
- Apr 20, 2021
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
LeifA wrote:Hi!
Everything else seems to work as before and other speed tests that use the Orbi WiFi works fine.
Testing with Orbi speedtest gives me a better value for the incoming speed from the modem.
Any suggestions why?
Regards
Leif
May 15, 2021Guru - Experienced User
IF your modem is in router mode, then Orbi should be in AP mode.
LeifA wrote:Should the Orbi be in AP mode if it is used as the only router after the modem?
Leif
LeifA
May 16, 2021Apprentice
As far as I know the modem is just a 4G modem, no router function.
I have removed the router thar was installed with the modem because that one could not be put in bridge mode. The ISP who supplies the 4G modem suggested that I connected the Orbi directly to their modem.
Leif
- FURRYe38May 16, 2021Guru - Experienced User
IF the 4G modem doesn't have a built in router, then you should connect the Orbi RBR in router mode to the modem.
LeifA wrote:As far as I know the modem is just a 4G modem, no router function.
Leif
- LeifAMay 16, 2021Apprentice
Yes, it is in router mode.
Some answer here suggested AP mode.
Leif
