Chizel84's avatar
Chizel84
Orbi RBR 50 - stopping functionality within certain apps?
  • As an example, if using sky sports football score centre it will open show the news but not any of the scores. When I switch to my vodaphone router (which feeds into my orbi) the scores come up instantly? Happens on numerous different apps and some web links. Can anyone help or guide what I should do? 1 week outside my warranty which is very annoying and typical timing
    • FURRYe38's avatar
      What is the Mfr and model# of the ISP modem the NG router is connected too? You have a built in router here, if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
      Couple of options,
      3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
