xyzw
Jan 01, 2022Aspirant
Orbi RBR 50 - Struggling to reconnect devices after reboot
Hi all, I have an Orbi 50 system with one satellite and approximately 40-50 devices connected (of which 10 wired through a switch and the others on wi-fi). Since a couple of months, after ove...
CrimpOn
Jan 01, 2022Guru - Experienced User
xyzw wrote:
Hi all,
I have an Orbi 50 system with one satellite and approximately 40-50 devices connected (of which 10 wired through a switch and the others on wi-fi). issue seems to be related to the wireless connectivity since wired devices reconnect within seconds.
The Orbi is running on the latest version of the firmware (V4.6.5.14). Has anyone experienced a similar issue and has found a solution?
It would help to know the specific model number of the Orbi (from the product label on the bottom of the router).
xyzw wrote:
Hoping to reduce DHCP overhead, I have been reserving IPs for most of the IoT devices in the house (approximately 30 devices that cannot be powered-off during reboots). This seems to help, but did not solve the issue.
DHCP has practically zero overhead. Only six tiny data packets are required to secure a 24 hour lease (86,400 seconds). All of those devices go through exactly the same sequence whether an IP has been 'reserved' for them or not. This is not to argue against assigning IP's to devices. Every device that regularly connects to my Orbi has an entry in the LAN Setup table. The point is that this is not the right area to focus on.
Rebooting the router every 30 minutes is probably doing more harm than good. When the Orbi system reboots, the router begins broadcasting WiFi significantly before the satellites do. If those IoT devices detect a poor router WiFi signal, they may 'stick' to it.
Rebooting the IoT device may be the best way to address this issue.
There are definitely concerns about satellite behavior in some of the newer AX models of Orbi.
- xyzwJan 01, 2022Aspirant
Hi piemans and CrimpOn,
thank you for your help.
As per the configuration
0. the exact models of the router / satellite system are
- Router RBR750
- Satellite RBS750
1. both router and satellite are running fimrware V4.6.5.14 (I believe this is the latest available)
2. the modem is proprietary and provided by the ISP, but network management options should have been fully tuned down (no DHCP service, no UPnP, port forwarding for used ports, ...).
3. Unfortunately most IoT devices are hard wired (e.g. Shelly or Tuya switches) and the only way to turn them off is through a power cycle at electric meter level, turning off and on the router / satellite as well.
I made a couple of tests and
1. devices try to connect both to router and satellite and they keep dropping off both for a while
2. the router definitely struggles as well alone. However in this case network quality is significantly worse for 10-15 devices
3. a clean firmware installation might be quite painful in terms of time. Is there any further step to troubleshoot the issue before resetting everything?
Thank you all for the help!
Stefano
- CrimpOnJan 01, 2022Guru - Experienced User
I am interested in how "dropping off" is observed:
- The devices appear in the Orbi Attached Devices (or 'app') and then later do not appear, or
- The smartphone app that manages the devices says they are not on-line?
- xyzwJan 02, 2022Aspirant
CrimpOn, thank you for your question. The devices appear in the Orbi app, in the "Network map" section by pressing on the router / satellite icon. They initially are listed with a green dot on the left (apparently) in a consistent way with the list of attached devices in the "Device Manager" section of the same app. When they "drop" they drop both from the list in the Network Map (being listed with a gray dot below conneted devices) and in the list in the Device Manager section.
This is not always consistent with feedback from third party apps that may or may not see the devices independently from the status reported in the Orbi app. Direct calls to local IPs from a web browser are not always successful either also when devices appear to be "connected" according to the app.
Looks like my Orbi has some issues in building the IP table for the wi-fi network, but I have no specific evidence supporting my guess.
Thank you for your help!
Stefano
