vonnymc
Feb 04, 2020Aspirant
Orbi RBR 50 & RBS 50 - i can't get my Google Nest Mini's to connect?
I have tried turning off the 5ghz in the advanced settings as suggested by FURRYe38 in another post but this hasn't made a different, infact i could still see that some devices had a 'connection type...
CrimpOn
Feb 04, 2020Guru - Experienced User
vonnymc wrote:I have tried turning off the 5ghz in the advanced settings as suggested by FURRYe38 in another post but this hasn't made a different, infact i could still see that some devices had a 'connection type' as 5ghz. Any other ideas welcomes before my kids go insane?
Nest Mini fully supports 2.4G and 5G WiFi, as reported in this spec:
"Wireless Connectivity 802.11b/g/n/ac (2.4 GHz/5 GHz) Wi-Fi, Bluetooth 5.0, Chromecast"
If these Mini's were previously connected to a different router ("Plusnet"), perhaps the easiest solution is to "reset" the Nest Mini's and set them up from scratch. https://support.google.com/googlenest/thread/20623727?hl=en
