mrm18
Jun 05, 2023Tutor
Orbi RBR 50 2.4 GHz connection issues
I have the Orbi RBR 50 with 2 RBS 50 satellites. I seem to be having issues with the 2.4 hz stability. When I look at the details on my app it just says connection Type 5Ghz. So I'm not even seein...
CrimpOn
Jun 05, 2023Guru - Experienced User
mrm18 wrote:
I have the Orbi RBR 50 with 2 RBS 50 satellites. I seem to be having issues with the 2.4 hz stability. When I look at the details on my app it just says connection Type 5Ghz. So I'm not even seeing the 2.4 suggestions on what to look at / fix?
Are there devices that support only 2.4G WiFi that are connected to the network and are working correctly?
And this is regarding user device connections, not the satellite to router 'backhaul' connection, correct?
mrm18
Jun 05, 2023Tutor
Yes the device that keeps having issues is my new Laser Printer. it will be the correct IP then dropps to an invalid IP. The techs says it's becuase it's having issues with the 2.4 Ghz. That is the only thing it can connect to.
- CrimpOnJun 05, 2023Guru - Experienced User
If you supply the model number, we can look at the user manual on line.
How long does the printer remain on-line with a valid IP address before it changes?
Does the invalid IP begin with 169.254?
- mrm18Jun 05, 2023Tutor
Yes it switches to the to 169... The printer I have is the Canon imageCLASS MF653Cdw. I spent a long time with their tech support and what she said was the printer connects to the 2.4GHz. That the printer gets the address from the router. That when it goes to the 169 IP that although it shows connected it really isn't. Very very frustrating.
The room that the printer is in, it is 10 feet or so from the satellite. The speed in the room is very fast per the app. But that is the 5.4 I since I can't see what is happening with the 2.4 I don't know if it's dropping in and out.
Thanks for providing the model number. On the setup process, does the Orbi WiFi SSID appear on the list of available networks (page 4, step 8)?
https://gdlp01.c-wss.com/gds/0/0300041600/03/MF656Cdw_SG_US_multi_1.pdf
After entering the password, the process appears to be successful? (printer displays an IP address consistent with the Orbi network?)
How much tiime elapses before the printer changes to the Link Local IP address? (169.254.x.x)?
Are there any other devices in the house that are connected to the 2.4G WiFi network? (smart plugs? light bulbs? garage door openers? thermostats? )
