mrm18
Jun 05, 2023Tutor
Orbi RBR 50 2.4 GHz connection issues
I have the Orbi RBR 50 with 2 RBS 50 satellites. I seem to be having issues with the 2.4 hz stability. When I look at the details on my app it just says connection Type 5Ghz. So I'm not even seein...
mrm18
Jun 05, 2023Tutor
Yes the device that keeps having issues is my new Laser Printer. it will be the correct IP then dropps to an invalid IP. The techs says it's becuase it's having issues with the 2.4 Ghz. That is the only thing it can connect to.
CrimpOn
Jun 05, 2023Guru - Experienced User
If you supply the model number, we can look at the user manual on line.
How long does the printer remain on-line with a valid IP address before it changes?
Does the invalid IP begin with 169.254?
- mrm18Jun 05, 2023Tutor
Yes it switches to the to 169... The printer I have is the Canon imageCLASS MF653Cdw. I spent a long time with their tech support and what she said was the printer connects to the 2.4GHz. That the printer gets the address from the router. That when it goes to the 169 IP that although it shows connected it really isn't. Very very frustrating.
The room that the printer is in, it is 10 feet or so from the satellite. The speed in the room is very fast per the app. But that is the 5.4 I since I can't see what is happening with the 2.4 I don't know if it's dropping in and out.
- CrimpOnJun 05, 2023Guru - Experienced User
Thanks for providing the model number. On the setup process, does the Orbi WiFi SSID appear on the list of available networks (page 4, step 8)?
https://gdlp01.c-wss.com/gds/0/0300041600/03/MF656Cdw_SG_US_multi_1.pdf
After entering the password, the process appears to be successful? (printer displays an IP address consistent with the Orbi network?)
How much tiime elapses before the printer changes to the Link Local IP address? (169.254.x.x)?
Are there any other devices in the house that are connected to the 2.4G WiFi network? (smart plugs? light bulbs? garage door openers? thermostats? )
- mrm18Jun 06, 2023Tutor
Yes it does appear successful and I can see the proper IP. Then when I turn it off and turn it back on, it still appears fine until I try to print. Then I'll get a message that the IP address has changed, which is always back to the 169 IP and it doesn't work any longer. Sometimes I can get it back to the 192 IP again by reconnecting to the network, but really I shouldn't have to and that doesn't always work. I am not having these issues with anything else. And it never appears to resets on it's own.
