chinashaw
Nov 30, 2020Aspirant
Orbi RBr 50 and ethernet backhaul
I currently have a BT home hub 5 connected to an RBR50 Orbi router (in AP mode) with 4 satellites attached to it. This is causing a few irritating issues and I am doing the following: a. Replacin...
Nov 30, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
chinashaw wrote:I currently have a BT home hub 5 connected to an RBR50 Orbi router (in AP mode) with 4 satellites attached to it. This is causing a few irritating issues and I am doing the following:
a. Replacing the BT homehub 5 with a netgear DM200 in modem mode and making the RBR50 a router.
b. My wife's office has her own Satellite but the backhaul is a bit too flakey at times for it to be reliable enough for all the video calls etc.
Question 1:
So to address that I ran an ethernet cable down towards the RBR50 Router but in order for it to get to it, I need to run that cable into an unmanaged (Netgear) switch and then another cable to the RBR50 Router. At the moment that doesn't work, going through the switch seems to cause it to fail, so we are back to the wifi backhaul.
Any thoughts? I have seen comments on where to plug the ethernet cable etc. So once I have changed the BT HH5 I will have a fiddle with the ethernet cable.
Question 2:
This is a configuration issue, I need to prioritise her computer traffic over the xbox traffic (terrible I know) and I wondered how to do this? Can I do this in the Orbi system?
Thanks,
Nicholas
PS
I am on a mac/iphone/ipad and she is on Windows.
