maurice-william
Sep 05, 2019Aspirant
ORBI RBR 50 cannot receive internet from cat6 cable
I have moved my orbi router and had to lay a long cat 6 internet cable (40m) from my modem to my orbi router. I connect the cat 6 cable from my modem to my orbi router it doesn't work but if I don't p...
Sep 05, 2019Guru - Experienced User
40 meters is kind of long. Though it should work. Did you power OFF the ISP modem and RBR for 30 seconds, then power ON the modem first and let it synce, then power ON the RBR with the 40m cable connected?
