Piggington
Jul 24, 2019Guide
Orbi RBR-50 cannot see all satellites
My RBR50 system has two satellites. They were running 2.3.1.44 on the other day when I was checking the system status. However, both Orbi App and direct login to router web page indicated that ...
- Jul 24, 2019
Now all ORBIs are running the same Firmware.
It seems that the extension cord, where the problematic satellite was getting its power, was flaky. By replacing the cord, I was able to update the firmware.
Now both Orbi App and web page are correctly showing 2 satellites. Problem solved.
Jul 24, 2019Guru - Experienced User
Is the RBR and RBSs all on the same version of FW now?
Piggington
Jul 24, 2019Guide
- FURRYe38Jul 24, 2019Guru - Experienced User
Glad you got it running. Enjoy. :smileywink:
