-Malux-
Dec 09, 2020Tutor
Orbi RBR 50 DHCP issue after Reboot
This issue is maddening. A simlpe router reboot causes DHCP to stop working. I have the satellite off, and the router just will not allow my iPhone 11 Pro (and most of the other devices on my ...
-Malux-
Dec 10, 2020Tutor
take a look at the log; i'm starting to wonder if this isn't an issue just with my Kasa switches...I have about 38 smart switches from kasa on my network
- -Malux-Dec 10, 2020Tutor
- FURRYe38Dec 10, 2020Guru - Experienced User
What are the model#s of these Kasa Switches?
-Malux- wrote:take a look at the log; i'm starting to wonder if this isn't an issue just with my Kasa switches...I have about 38 smart switches from kasa on my network
I have a total of 38 of them. They are HS200, HS 210, HS105. I have KASA Switches, Plugs, 3 Way Switches and Dimmers
What you might do is to either disconnect all these switches from the RBR. Do a full reboot of the RBR. Check it's operation. If it's stable, graduate adding a switch, 1 at a time, and see if the router can add them using this process. You might see about setting an IP address reservation ON the RBR for each.
