-Malux-
Dec 09, 2020Tutor
Orbi RBR 50 DHCP issue after Reboot
This issue is maddening. A simlpe router reboot causes DHCP to stop working. I have the satellite off, and the router just will not allow my iPhone 11 Pro (and most of the other devices on my ...
-Malux-
Dec 10, 2020Tutor
take a look at the log; i'm starting to wonder if this isn't an issue just with my Kasa switches...I have about 38 smart switches from kasa on my network
Dec 10, 2020Guru - Experienced User
What are the model#s of these Kasa Switches?
- -Malux-Dec 10, 2020Tutor
I have a total of 38 of them. They are HS200, HS 210, HS105. I have KASA Switches, Plugs, 3 Way Switches and Dimmers
- FURRYe38Dec 10, 2020Guru - Experienced User
What you might do is to either disconnect all these switches from the RBR. Do a full reboot of the RBR. Check it's operation. If it's stable, graduate adding a switch, 1 at a time, and see if the router can add them using this process. You might see about setting an IP address reservation ON the RBR for each.
There's no way I'm going rewire 38 wall-installed switches when i reboot my routher...That cant' be an acceptable possible solution.
I turned off DHCP and looked at a wireshark log. It looks like I'm getting 10-20 DHCP discover requests per second. Is it possible the router is seeing that as an attack an denying them?
Is it also possible the rotuer is not set to be authoratitive so the switches are still trying to get their old IPs back?
