-Malux-
Dec 09, 2020Tutor
Orbi RBR 50 DHCP issue after Reboot
This issue is maddening. A simlpe router reboot causes DHCP to stop working. I have the satellite off, and the router just will not allow my iPhone 11 Pro (and most of the other devices on my ...
-Malux-
Dec 10, 2020Tutor
There's no way I'm going rewire 38 wall-installed switches when i reboot my routher...That cant' be an acceptable possible solution.
I turned off DHCP and looked at a wireshark log. It looks like I'm getting 10-20 DHCP discover requests per second. Is it possible the router is seeing that as an attack an denying them?
Is it also possible the rotuer is not set to be authoratitive so the switches are still trying to get their old IPs back?
-Malux-
Dec 10, 2020Tutor
incidentally, I upgrade the firmware to 2.7.1.60. No change...
