mahart1975
Apr 02, 2021Initiate
Orbi RBR-50 dropping internet connection to modem intermittently
Figured I'd post my positive results here on a thorny issue with my Orbi system. I have an RBR-50 with an RBR-30 satellite and one of the wall plugin satellites. So about 3 weeks ago or so, I updat...
tucsontico
Apr 04, 2021Virtuoso
Thanks for your troubleshooting input. Seems pretty odd to me that a firmware update specifically designed to address "Security Vulnerabilities" (v2.7.2.104) would require the user to turn off a DoS attack prevention mode. However, if your set up is working well, then this may be the answer for the group of folks struggling with loss of internet due to the v2.7.2.104 firmware.
vajim
Apr 04, 2021Master
tucsontico wrote:Thanks for your troubleshooting input. Seems pretty odd to me that a firmware update specifically designed to address "Security Vulnerabilities" (v2.7.2.104) would require the user to turn off a DoS attack prevention mode. However, if your set up is working well, then this may be the answer for the group of folks struggling with loss of internet due to the v2.7.2.104 firmware.
If you look at the release notes on most of the recent firmware versions, most mention "Security Vulnerabilities"....almost like they use that as a way to get most folks to believe its important...??
