wolfereeno
Jul 26, 2023Apprentice
Orbi RBR 50 hacked - Netgear, what are you doing to protect us?
I got a suspicious email on gmail 2 weeks ago - one of those "whats up" with no message body. I don't think I even opened it, but something triggered in the msg preview and seemed to run something. ...
- Aug 04, 2023
Thx, between coverage issues upstairs, and needing ethernet jacks for the NAS in the mezzanine area, I ended up with 3 satellites. One thing I didn't realize is that the 5G signals probably have a harder time penetrating the metal walls around the BR and that 2.4 would have been better.
Anyway I appreciate your help. But it's kind of for naught.
Yesterday the internet in our neighborhood went out and when it came back on, the RBR50 would not reboot. Steady green light but nothing would reset it. I tried all the methods I could find. Even tftp would connect and seem to upload the file but then would fail.
So I went down to B&H photo and walked out with an ASUS XT9. Setup was a breeze. I'm trying just two units and opposite ends of the apartment. We'll see if my wife notices I moved the NAS to the bedroom! She wouldn't like it much in the living room either. Setup and performance seems good so far and hopefully I can stick with just the two units. I like that both units can be routers or satellites, which gives me options in case one fails or we move.
As for whether I was hacked a few weeks ago or the router was the initial stages of the router failing, who knows. I still think it acted like a hack.
The clincher to ditching netgear was seeing how many people report bricked RBR50s as well as how many have resorted to alternate firmware. I just don't have time for all that. So in the end if I can revive the RBR, great. Otherwise I'll just put the satellites on craigslist and be done with Netgear for a while.
Thx
Aug 01, 2023Guru - Experienced User
wolfereeno wrote:
I have bitdefender on all the machines. Is Malwarebytes substantially better? Yes.
As for too many satellites, the problem is the metal siding around the bedroom blocks the signal to the roof deck so there's a satellite by the sliding doors. I didn't want this many satellites - as I mentioned I started with just two. But with the levels and the deck issue, it grew...
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Also try turning down the power output of the RBRs wifi radios from 100% to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
wolfereeno
Aug 01, 2023Apprentice
The main RBR50 and the modem are in the living room. The next router is about 25' away up some stairs. The other two are then up more stairs and at opposite ends of the bedroom by the windows. It's an old nyc skinny NYC building that's about 15' wide and 60' long.
I could probably turn down the signals a bit. Thought right now, everything's running normally (and pretty good).
- FURRYe38Aug 01, 2023Guru - Experienced User
Where is this Mezzanine? Lower level under or near the bedroom where RBS 4 is?
RBS 3 and 4 are too close to each other. You might try turning OFF #4 RBS.
Ya, I'd turn down the power to 50% or 25% and observe.
- wolfereenoAug 04, 2023Apprentice
Thx
- FURRYe38Aug 04, 2023Guru - Experienced User
Yes, higher frequency is more susceptible to building materials. Nature of the beast for any wifi router.
Try a 30-30-30 reset.
Possible failure of the FW as well.
Good Luck.
