dbeelaert
Apr 13, 2020Aspirant
Orbi RBR 50 has problems with my new ATT Fiber gateway
Hello Techy People, I could really use your help! I am NOT a technical user but I need some help in fixing a problem. My "help support" that was free through Orbi expired 10 days ago, and I real...
- Apr 13, 2020
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router and wifi here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend trying option #3 first. Contact your ISP for help and information about the ISP gateway.
dbeelaert
Wow, you are amazing!
I don't know all the details, but YES it's a modem and WiFi router combo.
I've attached a picture of the back of the modem...does this make sense to you?
Apr 13, 2020Guru - Experienced User
Again, FURRYe38 was correct. Its a combo device. Try running the orbi in AP (access point) mode.
