Tbreneau
Jul 07, 2019Aspirant
Orbi RBR-50 internal speed check with modem half the ISP speed
I have a 1Gig service from Xfinity and at their modem I verified speed of 999, however when checking speed of same connection between my Orbi Router and the Xfinity modem via o Netgear internal Orbi R...
Jul 07, 2019Guru - Experienced User
Can you try AP mode with the Orbi connected to your ISP modem if it has a built in router?
FYI:
Tbreneau
As Stated in original post I did and in bridge AP mode as well no effect as well in DMZ with wireless turned off. Still the same low link speed between the Otni RBR50 router and the Xfinity CGM4149COM cable modem. Again if I direct connect a pc to the modem I get full speed, when I plug orbi into same port the router to modem the orbi internal speed test shows less than half the speed being supplied. Latest Firmware update 2.3.1.60.
- TbreneauJul 07, 2019AspirantTypo “Orbi RBR50” router. My iPhone voice to text translation not perfect.
- FURRYe38Jul 07, 2019Guru - Experienced User
While the modem is in bridged mode, factory reset the RBR and it up from scratch. Be sure to not enabled the QoS speedtest, traffic meter or access controls. With a wired PC, test the speed.
My testing with v60 on RBR50 is not seeing much over 300Mbps and think there is a problem with the WAN to LAN speeds.
- TbreneauJul 07, 2019AspirantSame here there is a problem
Please file a support ticket here.
https://www.netgear.com/mynetgear/registration/login.aspx
Can reference this forum thread please.
