Tbreneau
Jul 07, 2019Aspirant
Orbi RBR-50 internal speed check with modem half the ISP speed
I have a 1Gig service from Xfinity and at their modem I verified speed of 999, however when checking speed of same connection between my Orbi Router and the Xfinity modem via o Netgear internal Orbi R...
Jul 07, 2019Guru - Experienced User
While the modem is in bridged mode, factory reset the RBR and it up from scratch. Be sure to not enabled the QoS speedtest, traffic meter or access controls. With a wired PC, test the speed.
My testing with v60 on RBR50 is not seeing much over 300Mbps and think there is a problem with the WAN to LAN speeds.
Tbreneau
Same here there is a problem
