Tbreneau
Jul 07, 2019Aspirant
Orbi RBR-50 internal speed check with modem half the ISP speed
I have a 1Gig service from Xfinity and at their modem I verified speed of 999, however when checking speed of same connection between my Orbi Router and the Xfinity modem via o Netgear internal Orbi R...
Tbreneau
Same here there is a problem
Jul 07, 2019Guru - Experienced User
Please file a support ticket here.
https://www.netgear.com/mynetgear/registration/login.aspx
Can reference this forum thread please.
- tuna_ertemalpJul 13, 2019Luminary
Just as an added voice to the thread: I am on 1G/40M service from Xfinity, too, with an RBR50v2, running 2.3.1.60, initially set up having been connected for the first time to the cable modem AFTER that NEW Docsis 3.1 Xfinity modem was un-shrinkwrapped and set to bridge mode with all radios/SSIDs turned off by the Xfinity folk. And, the internal Speedtest of the router is consistently at about 510/40.
Now, here is the kicker: The wired LAN output from that RBR50v2 goes into a gig switch, which goes into another gig switch, and that goes into my PC running Win10. And, using the Speedtest Windows app (not the website), against Comcast or Speedtest servers around Seattle. When running against Speedtest server, I get 900/50. When running against Comcast server, I get 480/40. Wut?
So, I would be very interested in hearing what the OP hears from NG. I am wondering if these results depend on the test server, or if there is a math error in the way the router's numbers are dislayed. Consistently "half" the max speed seems a bit too... ...coincidental.Tuna
And, using the latest 2.3.5.30 firmware, I am still getting a reported 515/42 on my 1000/40 service fro Xfinity, per the internal Speedtest.
- FURRYe38Jul 13, 2019Guru - Experienced User
tuna_ertemalp wrote:And, using the latest 2.3.5.30 firmware, I am still getting a reported 515/42 on my 1000/40 service fro Xfinity, per the internal Speedtest.
