JudeMills
Oct 01, 2017Tutor
Orbi RBR 50 New firmware v2.0.0.74: Can you enable MU-MIMO, fast roaming and Beamforming now??
Wondering if under the newest firmware v2.0.0.74, you can now enable Beamforming, MU-MIMO and fast roaming? Under the older firmware version, Netgear suggested unclicking those boxes to get the syste...
JudeMills
Oct 01, 2017Tutor
Good info. Thanks for the feedback. Hoping the daisy chain feature works, since want to buy another satellite [currently have 2] and it would be placed where it would have to connect to a satellite since it would be too far away from the router to be able to establish a connection.
peteytesting
Oct 01, 2017Hero
it works but its very sensitive to placement and you need to make sure its well out of range of the router or it will and can cause connectivity issues
eg there should be no wireless overlap from the router where you want to set the third sat
so like
sat -------- router --------- sat --------------sat
