kwonkor
Nov 26, 2018Aspirant
Orbi RBR 50 no internet connection
My orbi worked find till yesterday, and todat just it died with no reason.
I can connect the internet through the modem to pc directly, but If I plug the cable modem to orbi and to pc then no signa...
Nov 26, 2018Guru - Experienced User
What FW is currently loaded?
Have you tried a factory reset on the Orbi router then walk thru the setup wizard?
Can you still access the routers web page?
Is the top LED giving any color indication?
kwonkor
It's v2.2.1.210
I'm using Arris SB6183 modem with xfinity.
I have clicked reset button twice and giving me steady white color LED. If I do the troubleshoot on window, it keeps blinking white. No purple.
I have not tried to go into routers webpage. shoud I?
