Peace2u3
Jan 16, 2021Aspirant
Orbi rbr 50 Port forwarding issues
I am trying to add ports 80, 8000, and 554 to my orbi so i can remotly see my truvision camera system. Router Firmware Version V2.5.2.4. I install these systems regularly but this is the first time...
Jan 16, 2021Guru - Experienced User
You night update FW to v40 and see:
Update the RBS first then RBR lastly. Then factory reset and setup from scratch.
uPnP should be disabled when using PF configurations
Peace2u3
Updated FW V40
-didn't help
i'd really rather not factory reset it again i tried that and it didn't help. I know it's a new FW but I'm not sure how much help that will be.
I was refering to the upnp as in I tried using it when the PF first wasn't working but it is off.
Modem is
-Arris CM8200A and it is connected to a RBR 50 Orbi Router.
- FURRYe38Jan 16, 2021Guru - Experienced User
I would contact the Mfr of your devices for additional help and information regarding any port forwarding configurations needed for there product to ensure your getting correct configurations needed.
