Adrianbrazen
Dec 03, 2021Follower
Orbi rbr 50 reboots everyday
everyday since i have updated to Firmware Version 2.7.3.22 my router reboots every morning around 9:00 AM. When I check the logs the below message is what I see: [Initialized, firmware version: V2.1...
Dec 06, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
