Paul_Tepper
Mar 29, 2023Aspirant
Orbi RBR 50 router firmware - 2.7.4.24 or 2.7.5.4?
Hi folks, The admin firmware update page says that the current firmware for the RBR 50 router is 2.7.4.24 but the Orbi page, https://www.netgear.com/support/product/rbr50#download, says its 2.7.5...
- Mar 29, 2023Thank you
Mar 29, 2023Guru - Experienced User
2.7.5 comes after 2.7.4.
NG sometimes doesn't push or make avialble updates on the RBR so it's up to you if you want to update or not. You don't have to.
I recommend if you do, manually update as suggested here:
Paul_Tepper
Thank you
