ThKu's avatar
ThKu
Follower
Oct 09, 2021
Orbi RBR 50 slow download speed, but upload OK
For a year my Orbi RBR50 worked perfectly fine. I have a 500MB download/500MB upload fibra connection, but now I get only 3MB download while the upload continues at full speed. The Orbi is directly connected to the fibre router. I have disconnected it, restarted it, but to no avail. What can I do?
1 Reply
  • FURRYe38's avatar
    How are you speed testing? Wired or wireless. Wired is preferred thru the RBR.
    Armor, Circle, Traffic Meter.
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
