fwt1968
Jul 29, 2018Initiate
Orbi RBR 50 Slow WiFi speed
I have a Spectrum Internet connection rated at 200 Mbps. I am getting slightly more on downloads.
Speedtest on my phone is more like 15 Mbps. Phone is Samsung 8+. sitting in room next to router...
Jul 29, 2018Guru - Experienced User
Turn off the sateliites and then connect the phone to the router and try a speed test. Turn back on after testing...
Also try a speed test with speedtest.net app and not the Orbi app on the phone.
How big is your home? SqFt?
What is the disatance between the router and satellites?
Disable MIMO, Daisy Chain and Fast Roaming.
fwt1968
Thanks. WWM was diabled. When enabled, speed is now 200+ Mbps. I was using Speedtest on phone to check speed.
I have disabled daisy chain only at this time.
