fwt1968
Jul 29, 2018Initiate
Orbi RBR 50 Slow WiFi speed
I have a Spectrum Internet connection rated at 200 Mbps. I am getting slightly more on downloads.
Speedtest on my phone is more like 15 Mbps. Phone is Samsung 8+. sitting in room next to router...
mikemiddleman
Jan 29, 2019Initiate
Update:
Spectrum physically came to my property and identified that squirrels had chewed on the line coming into my home. The end cause of the issue was moisture impacting the signal coming into my house. Humidity levels and rain dramatically reduced speeds, the heat of the day would dry out the line and return speeds to normal. When the technician came and removed the wire water was pouring out like a straw...
In summary as a last resort have the signal to your modem checked and ensure there is not physical damage to your line before you lose your mind like I did and swap out all your hardware.
Jan 29, 2019Guru - Experienced User
Glad you go it figured out. Darn squirrels.
Enjoy now. :smileywink:
mikemiddleman wrote:
Update:
