Sovby
Mar 04, 2022Aspirant
ORBI RBR 50 V2 Loses Ethernet connection
Ive been using this router for 3 or 4 months with everything working fine, but a few days ago it started giving me problems. i lose my ethernet connection to my windows 10 computer. It says ip addres...
Mar 05, 2022Guru - Experienced User
What xfinity modem is it connected to?
What firmware version are you on?
Sovby
Mar 05, 2022Aspirant
The xfinity modem is CGM4140COM. Here is what i found on xfinity website.
- Model Numbers: TG3482G and CGM4140COM
- Friendly Model Name: XB6
- Gigabit Ethernet Ports: 2
- Dual-Band WiFi Option: Yes
- 2.4 GHz Connected Client Limit: 30
- 5 GHz Connected Client Limit: 75
- Maximum Data Throughput: 1 Gbps
- WPS (WiFi Protected Setup): Yes
- Gateway/ Network Management Tool (http://10.0.0.1): Yes
- Xfinity xFi Eligible: Yes
- Xfinity xFi Advanced Security: Yes
- Xfinity app Activation: Yes
- Two Total Telephone Ports: Yes
- Battery Backup Capability (Xfinity Voice Only): Yes
- Link Cordless Phones (CAT-iq 2.0*): YesHome Hotspot Capable: Yes
- Compatible with Xfinity Home Pro Protection: Yes
- Compatible with Xfinity Home Self Protection: Yes
The download speed was 106mbps and the upload speed was 23.2 mbps using wifi. I'm not sure how to see the firmware. i googled it and it said to put in username & password. Im not a network administrator or anything but that doesnt sound very secure. is there a better way to see this? i'm using the netgear router so xfinity turned on briging i think its called?
- SovbyMar 05, 2022Aspirant
i also have a 8 port netgear GS308E Smart managed Plus switch.
- FURRYe38Mar 05, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- SovbyMar 05, 2022Aspirant
i was under the impression that the modem is in bridge mode. I have spoken to xfinity about this.
FURRYe38 wrote:Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
This setup has been working for a few months but now it does not like something. Either there ws an update or some other reason that has made things not compatiable.
