Sovby
Mar 04, 2022Aspirant
ORBI RBR 50 V2 Loses Ethernet connection
Ive been using this router for 3 or 4 months with everything working fine, but a few days ago it started giving me problems. i lose my ethernet connection to my windows 10 computer. It says ip addres...
Sovby
Mar 05, 2022Aspirant
The xfinity modem is CGM4140COM. Here is what i found on xfinity website.
- Model Numbers: TG3482G and CGM4140COM
- Friendly Model Name: XB6
- Gigabit Ethernet Ports: 2
- Dual-Band WiFi Option: Yes
- 2.4 GHz Connected Client Limit: 30
- 5 GHz Connected Client Limit: 75
- Maximum Data Throughput: 1 Gbps
- WPS (WiFi Protected Setup): Yes
- Gateway/ Network Management Tool (http://10.0.0.1): Yes
- Xfinity xFi Eligible: Yes
- Xfinity xFi Advanced Security: Yes
- Xfinity app Activation: Yes
- Two Total Telephone Ports: Yes
- Battery Backup Capability (Xfinity Voice Only): Yes
- Link Cordless Phones (CAT-iq 2.0*): YesHome Hotspot Capable: Yes
- Compatible with Xfinity Home Pro Protection: Yes
- Compatible with Xfinity Home Self Protection: Yes
The download speed was 106mbps and the upload speed was 23.2 mbps using wifi. I'm not sure how to see the firmware. i googled it and it said to put in username & password. Im not a network administrator or anything but that doesnt sound very secure. is there a better way to see this? i'm using the netgear router so xfinity turned on briging i think its called?
Sovby
i also have a 8 port netgear GS308E Smart managed Plus switch.
