jaws1554
Jan 08, 2022Aspirant
Orbi rbr 50 v2 satellite not showing blue ring to show its connected
When I try to sync the satellite it flashes white 3 times and the on third time the flash ends quicker then on the first two flashes. It will do this for 4 or 5 times and then just stop with no blue r...
CrimpOn
Jan 08, 2022Guru - Experienced User
There is no harm in Factory Resetting the satellite and adding it again:
- Power off the satellite.
- Go to the Orbi web interface, Attached Devices page and click on the option to "Remove" the satellite.
- On the Satellite, power it on and hold a paperclip in the reset hole until the LED next to the power switch begins to flash amber.
- Remove the paperclip.
- After the satellite restarts, go back to the Orbi web interface
- Select the bottom item on the Home Page menu, "Add Orbi Satellite"
- Follow directions.
Whereas doing a factory reset on the router erases all user configuration, resetting the satellite does not.
jaws1554
Have reset and reconnected and seem to be having the same problem. I have the satellite right next to the roku and still losing signal on ruko
