jaws1554
Jan 08, 2022Aspirant
Orbi rbr 50 v2 satellite not showing blue ring to show its connected
When I try to sync the satellite it flashes white 3 times and the on third time the flash ends quicker then on the first two flashes. It will do this for 4 or 5 times and then just stop with no blue r...
jaws1554
Have reset and reconnected and seem to be having the same problem. I have the satellite right next to the roku and still losing signal on ruko
CrimpOn
Jan 08, 2022Guru - Experienced User
How does the Orbi web interface Attached Devices or the Orbi 'app' show the satellite connection? (Good? Fair?...)
- jaws1554Jan 08, 2022AspirantGood
- jaws1554Jan 08, 2022AspirantI noticed everything is connected to the router. I have 1 device on the satellite. Is there a way I get devices to connect to satellite?
- CrimpOnJan 08, 2022Guru - Experienced User
When the satellite was 'off', devices probably migrated to the router. Either they will eventually migrate back, or you can power off the device and when it restarts it should connect to the satellite.
