Macsteffen
Oct 28, 2021Aspirant
ORBI RBR 50 V2
Hi. There
After "updating" my IOS units to IOS 15.1, I get a integritywarning, saying that my ORBI is blocking encrypted DNS traffic and other units on the network can see my internetactivities ??
How do I fix this, because I can not get into my internetbank ect ??
Thanks for Your answer, allthough I do not understand all this mumbo jumbo :-))), but I can tell You that an update and restart of Orbi fixed the problem.
Many thanks for Your effeort to help
macsteff
Its coming from apple's side.
Are you using wpa2?
Do a quick google search on that subject and you find tons of threads on it.
https://discussions.apple.com/thread/251905649
https://forums.macrumors.com/threads/this-network-is-blocking-encrypted-dns-traffic.2294587/
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
Macsteffen wrote:
Hi. There
- MacsteffenAspirant
macsteff
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemPlease visiting the main Orbi AC forum for your future needs.
Enjoy.
