RobU
Jul 02, 2021Aspirant
Orbi RBR 50 Verizon FIOS
I purchased Orbi RBR50 with a single satellite RBS50 directly from verzion back in 2018. I was not aware at the time that Verizon has it's own proprietery firmware V2.1.4.16_1.0.0.11 on these dev...
Jul 06, 2021Guru - Experienced User
Any progress on this?
RobU wrote:I purchased Orbi RBR50 with a single satellite RBS50 directly from verzion back in 2018. I was not aware at the time that Verizon has it's own proprietery firmware V2.1.4.16_1.0.0.11 on these devices. The firmware can't be upgraded and the biggest problem i have is that i want to create more coverage in my home. I purchased a satellite from Netgear and it was during this time that i discovered that the new unit would not pair up with the router. I was able to return for a full refund.
I am happy with the Orbi . I think its a great product. I dont want to spend several hundred dollars on a brand new system.
I didnt try to get support from Verizon yet. Searching the internet , it seems people that have a similar situation were not able to get it resolved. I would be content buying compatible satellites that have the same firmware but am unable to locate them anywhere.
I dont want to blame netgear for this but i have to quesiton why they would allow another vendor to write their own code that basically locks the end user out of upgrading. It should be on netgear to provide a solution.
- RobUJul 13, 2021Aspirant
Thank you for your reply but Verizon was of no help. I lost the fight t in me after 90 minutes of getting switched around and still not being able convey my message. I gave up when the last person i was on with wanted to sell me a new plan cause he thought i wanted to upgrade my wifi. It was cost effective for me to purchase new mesh system from netgear.
- FURRYe38Jul 13, 2021Guru - Experienced User
You can try this if you feel like you want to:
https://community.netgear.com/t5/Orbi/Upgrading-ISP-branded-Verizon-Orbi-RBR50-and-Orbi-RBS50-to-new/m-p/1978380/highlight/true#M103180
https://community.netgear.com/t5/Orbi/Orbi-RBK50-upgrade-ISP-branded-old-firmware-to-latest-firmware/m-p/1920034/highlight/false#M93253- RobUJul 13, 2021Aspirant
I enabled TFTP on my win 10 laptop. The attempt to transfer a file fails. I can only surmize that the device. is not listening on udp 69
