RobU
Jul 02, 2021Aspirant
Orbi RBR 50 Verizon FIOS
I purchased Orbi RBR50 with a single satellite RBS50 directly from verzion back in 2018. I was not aware at the time that Verizon has it's own proprietery firmware V2.1.4.16_1.0.0.11 on these dev...
RobU
Jul 13, 2021Aspirant
Thank you for your reply but Verizon was of no help. I lost the fight t in me after 90 minutes of getting switched around and still not being able convey my message. I gave up when the last person i was on with wanted to sell me a new plan cause he thought i wanted to upgrade my wifi. It was cost effective for me to purchase new mesh system from netgear.
Jul 13, 2021Guru - Experienced User
You can try this if you feel like you want to:
https://community.netgear.com/t5/Orbi/Upgrading-ISP-branded-Verizon-Orbi-RBR50-and-Orbi-RBS50-to-new/m-p/1978380/highlight/true#M103180
https://community.netgear.com/t5/Orbi/Orbi-RBK50-upgrade-ISP-branded-old-firmware-to-latest-firmware/m-p/1920034/highlight/false#M93253
- RobUJul 13, 2021Aspirant
I enabled TFTP on my win 10 laptop. The attempt to transfer a file fails. I can only surmize that the device. is not listening on udp 69
- CrimpOnJul 13, 2021Guru - Experienced User
RobU wrote:I enabled TFTP on my win 10 laptop. The attempt to transfer a file fails. I can only surmize that the device. is not listening on udp 69
My owb personal experience with tftp has been mixed.There seems to be a short window of opportunity after power is applied when the router listens for a tftp connection. Too early or too late and it doesn't happen. I seem to recall it taking 5 or 6 attempts to hit the sweet spot and make the firmware load.
Thanks again for your help. I made several attempts to both the Satellite and the router with no success. I dont think you could see the picture of my previous post. it was of a wireshark trace . my setup on the laptop /TFTP client and connectivity is sound. the netgear just doesnt allow for the TFTP connection. I have achieved what i really needed by buying a new Orbi mesh system with additional satellites. Unfortunately this was a costly solution. I still go back to my original point as to why or how Netgear would allow another vendor to put thier own code on a box. This pretty much locks you out. I wouldnt mind so much if i could have bought a satellite from Verizon or if Verizon just didnt up and decide that the dont support the orbi's any longer and dont provide a solution to anyone who purchased through them . Nor do they have people familiar with the fact that they did sell these devices and they did their own lousy engineering buy developing proprietery firmware. The RBS/RBR50 is a fine product. i just needed more coverage :( . I will wind up giving this system to someone in need.
