Benzai
Sep 17, 2019Follower
Orbi RBR 50 will not reset
My Orbi RBR 50 is no longer working and the reset procedure does not work. I can see the unit is powered on, the green led in the back is lit. When pressing the reset button with power on, nothing ha...
Sep 17, 2019Guru - Experienced User
You can try a tftp procedure.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Make sure you enable tftp within windows 10 or you'll get errors.
