Nettyspaghetti
Mar 19, 2019Follower
Orbi RBR 50
Hi A quick question to anyone who can help. I have an orbi RBR 50 and satellite and wondered if I can add another satellite to it to boost my house WiFi signal I have had problems with my signal sin...
Mar 19, 2019Guru - Experienced User
Yes you definitely can add another satellite if you're only running one. What one depends on your setup and what you're using it for. this site breaks it down a little so you can see what specifics you need (extra backhaul speed, ethernet ports, etc)
https://www.tech21century.com/netgear-orbi-rbk30-vs-rbk40-vs-rbk50/
