Nettyspaghetti
Mar 19, 2019Follower
Orbi RBR 50
Hi A quick question to anyone who can help. I have an orbi RBR 50 and satellite and wondered if I can add another satellite to it to boost my house WiFi signal I have had problems with my signal sin...
Mar 19, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Nettyspaghetti wrote:
Hi
A quick question to anyone who can help. I have an orbi RBR 50 and satellite and wondered if I can add another satellite to it to boost my house WiFi signal I have had problems with my signal since virgin media changed to the super hubs and found it has improved with the orbi but I may need to reduce the distance between the existing satellite and router and therefore add another satellite. If I can add another satellite which one would be recommended
Cheers
- Chuck_MMar 19, 2019Mentor
Short answer, Absolutely.
I have three satellites (RBS50s) in my house and they work superbly.
Another thing to think about is the associated backhaul -- e.g. how they connect back to the main router.
The optimal solution is to hard wire them if possible to maximize speeds. Of my three, I have two hardwired and the third uses RF to communicate back to the router.
See Orbi Network diagram below
