johninuk
Oct 01, 2019Aspirant
orbi RBR problems
hello please can you help I have minimal IT skills, ihave a orbi RBR50 and BRs50 satalites when i check the app it says they are all connected and working good, i have 3 satalites all not that far away from eash other so should have supper wifi conisdering the cost but even though it says they are all working fine it seems we are connected to the main router and if we go in any other room even with the satalite in the room we cant get internet.
we only have 1 wifi connection so cant get that wrong
if i disconnect one of them they all go red and when they re sync they are all good they seem like they are all working as they should but just not sending a wifi around the house
any ideas what i need to do
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
- johninukAspirant
i dont know what all them letters mean sorry, we have the latest firmware i do know that i will go through you list and try fine all them bits and check them
i have a vodafone router
some of the settings in the app
WPA2-PSK [AES]
Hardware Version RBR50 Firmware Version V2.3.5.30 GUI Language Version V1.0.0.360 Operation Mode AP is AP mode right ????- johninukAspirant
i have a big house but only need internet in part of it they are all 20 to 30 feet from each other
