cdbarker's avatar
Feb 28, 2024
Orbi RBR050 100MBps speed drop between PC and modem via Orbi
Hi  I have recently upgraded from 500MBps to 1GBps package with Virgin Media. I was sent a VM Hub 5 as part of this upgrade. I have noticed this download speed test difference.   I have the follo...
  • CrimpOn's avatar
    Feb 28, 2024
    Because the  RBR50 has only gigabit Ethernet interfaces (on both WAN and LAN ports).
    The highest transfer rate through gigabit Ethernet is slightly less than that because there is some "overhead" in Ethernet communication. (spaces between packets. packet 'wrappers', etc.)
