cdbarker
Feb 28, 2024Guide
Orbi RBR050 100MBps speed drop between PC and modem via Orbi
Hi I have recently upgraded from 500MBps to 1GBps package with Virgin Media. I was sent a VM Hub 5 as part of this upgrade. I have noticed this download speed test difference. I have the follo...
- Feb 28, 2024
Because the RBR50 has only gigabit Ethernet interfaces (on both WAN and LAN ports).
The highest transfer rate through gigabit Ethernet is slightly less than that because there is some "overhead" in Ethernet communication. (spaces between packets. packet 'wrappers', etc.)
cdbarker
Feb 28, 2024Guide
Thanks CrimpOn. I guess that to satisfy my urge for the extra 100Mbps, I'd have to upgrade to a router with a 2.5Gbps port.
CrimpOn
Feb 28, 2024Guru - Experienced User
Actually worse than that. Both the WAN port and at least one LAN port would have to be greater than 1 gigabit Ethernet.
There are lots of routers with a WAN speed higher than gigabit. It's the LAN side that is the issue. (Notice the Virgin hub has only a single 2.5G port. What most 'speed conscious' users do is connect the single 2.5G port to a 2.5G switch and then hook their array of speedy devices to that switch.)
