Blaize12
Apr 17, 2020Tutor
Orbi RBR10 - Unable to play Amazon Prime
Since setting up the Orbi mesh and WiFi, once connected we are unable to play Amazon Prime or SkyGo videos. It works fine (we are able to stream videos) if we reconnect to original router which the O...
- Apr 17, 2020
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Blaize12 wrote:Since setting up the Orbi mesh and WiFi, once connected we are unable to play Amazon Prime or SkyGo videos. It works fine (we are able to stream videos) if we reconnect to original router which the Orbi is connected to.
Blaize12
Apr 17, 2020Tutor
Hi, so it’s an out of the box setup with the Orbi router connected via cat5 Ethernet cable to my Plusnet router. The orbi is a mesh with two satellites to widen the WiFi signal. I’ve set up an orbi WiFi network which we use and works fine with YouTube videos and BBC iPlayer. We seem to get the error only when trying to watch something from either Sky or amazon Prime app. We can still connect to the Plusnet WiFi network and can happily use Sky/amazon apps fine it’s only on the orbi network where we get the errors.
CrimpOn
Apr 17, 2020Guru - Experienced User
The Sky and Amazon Prime apps are running on what? (smart TV? smartphone? tablet?)
- Blaize12Apr 17, 2020TutorHi, trying to run on an iPad. In answer to the earlier answer it’s an extender router so doesn’t have a dsl / phone jack so I have setup as per the instructions. It’s not a modem router. Thanks
