Blaize12
Apr 17, 2020Tutor
Orbi RBR10 - Unable to play Amazon Prime
Since setting up the Orbi mesh and WiFi, once connected we are unable to play Amazon Prime or SkyGo videos. It works fine (we are able to stream videos) if we reconnect to original router which the O...
- Apr 17, 2020
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Blaize12 wrote:Since setting up the Orbi mesh and WiFi, once connected we are unable to play Amazon Prime or SkyGo videos. It works fine (we are able to stream videos) if we reconnect to original router which the Orbi is connected to.
Apr 17, 2020Guru - Experienced User
Couple of options,
Retired_Member
Apr 17, 2020for clarification:
Double NAT is when you connect your router behind another router creating two different private networks. For example, connecting your NETGEAR router behind a modem/router provided by your ISP.
- CrimpOnApr 17, 2020Guru - Experienced User
I would be really fascinated to learn what exactly (in technical sense) about a "Double NAT" interferes with Amazon Prime or SkyGo. In fact, how having two NATs (Network Address Translations) would be any different than having one.
As I understand it, no router accepts connection attempts from the internet unless a port is "opened" to allow it. When a device is "behind" two routers, the first router "translates" the IP address of every device into a specific port on the outgoing connection. The second router then thinks, "oh, my, this ONE IP address wants to make a bunch of connections. I will "translate" them all to different ports on MY IP address." When a packet comes back, the NAT engine looks at it and says, "oh, this belongs to a specific IP address on my LAN side. I will translate it and pass it on." The second router then says, "oh, this belongs to a specific IP address on MY LAN side. I will translate it and pass it on."
Having a Double NAT makes opening ports impossible, because even though we may have opened a port on the first router, the second router has not. So, things like VPN connections, hosting web sites, accepting gaming connections, etc. will fail because the Orbi has opened a port waiting for a connection that can never happen. What is going on with Amazon Prime and SkyGo streaming?
