KEB12
Dec 07, 2022Aspirant
Orbi RBR10 and Alexa Echos in Stereo
Wanted my IoT devices on the Guest network for security reasons. Seems like a reasonable idea. The problem is is you want to have two Echo devices setup in Stereo (and of course on the Guest netw...
Dec 07, 2022Guru - Experienced User
so you're complaining because the way amazon setup their echos, they need to be on the same local network without client isolation?
Basically what it comes down to.
If you want to use them in stereo, put them on the local network. that's something coming from amazon.
It tends to be the IoT devices like switches/bulbs/cameras/etc that are a little more security sketchy.
and the
KEB12
Dec 31, 2022Aspirant
Hi Plemans,
So what I'm hearing is to put the Echo devices on my Main network and all of the IoT devices (switches/bulbs/cameras/etc) on the Guest network. Is that correct and will that work?
Thanks,
Keith
