AJLZ88
Feb 04, 2022Follower
Orbi RBR10 Anywhere Access
I turned on the Anywhere Access, now I can’t get it to toggle back to off. Ever since I turned it on I’ve been having WiFi connection issues & when I attempt to turn off Anywhere Access it states that This operation is not available using Anywhere Access. I turned it on via the Anywhere Access toggle so why is it that it’s not available to turn it off now? Any information regarding this will be greatly appreciated.
1 Reply
Be sure your connected locally to the RBR on the Orbi app and not the Cloud icon access, before trying to disable Anywhere Access.
https://kb.netgear.com/000058239/How-do-I-enable-or-disable-Anywhere-Access-on-my-NETGEAR-or-Orbi-router
https://kb.netgear.com/000064332/Why-is-Anywhere-Access-enabled-by-default-on-my-NETGEAR-or-Orbi-routerNetgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
