PaulR1975
Mar 19, 2024Aspirant
Orbi RBR10 connection to samsung phone.
Here's my setup: My Orbi RBR10 mesh router is connected to the Starlink router and has 6 satellites, distributed around the house, detached garage and greenhouse. I use the system for wifi calling b...
CrimpOn
Mar 19, 2024Guru - Experienced User
What a crazy situation! It seems so obvious: Samsung changed software in the phone and now it doesn't work. But....
Changing the User Interface (UI) is not necessarily the same thing as changing the mechanics of how the phone functions. The sense I get from the problem description is that voice quality when using internet calling was what led to the investigation of network speed. i.e. the A54 is just "slow" now when it was speedy before.
No, there is nothing different about Orbi WiFi compared to other similar products. IEEE 802.11 b/g/n/ac is a standard. The "10-series" product is similar to the original Google Mesh in being a Dual Band system, where the same 5G WiFi radios are used for both user devices and communication between router and satellites.
Sad to hear that the A54 does not display the network speed in WiFi settings. (My Samsung tablet does.)
There are two ways that the Orbi network connection and the Starlink connection are 'different':
- When connected to Starlink, none of the other devices connected to the Orbi are visible to the A54. (The original post did not mention which 'mode' the Orbi router is using.) If the A54 is consuming resources communicating with some other device on the Orbi network, that usage would stop when the phone connects to Starlink directly. It's a real frustration that Orbi routers do not provide useful information about which devices are using the network.
- When connected to the Orbi system, we assume that the phone is correctly implementing IEEE802.11r (often called Fast Roaming - https://en.wikipedia.org/wiki/IEEE_802.11r-2008 ) to be connected to the optimal Orbi unit at all times. With six satellites in that layout, there is a good chance that some are "Daisy Chained" and this may affect speed at the farthest satellite. Would it be possible to temporarily power off the satellites and test the phone against only the Orbi router? The Orbi Attached Devices (Device Manager on the Orbi app) display which unit each device is using. The Orbi app also displays the Link Speed which it appears that the A54 does not reveal. It is frustrating that the attachment information takes quite some time to update. (we think of computers as being "instant". The Orbi Attached Devices information can take several minutes to change, and often requires an actual "Refresh" of the screen.)
The A54 has probably been restarted?
PaulR1975
Mar 20, 2024Aspirant
Thanks for the reply, much appreciated.
The Orbi router is in Router mode, as it always has been, and it shows the phone connected with 5G. I have cleared cache, reset all settings, and also done a factory reset, but with no improvement in performance. I suppose I could power down all satellites, then check the wifi speed from the Orbi router.
I don't remember which was the 1st symptom, whether speed or voice communication. I think possibly it was speed, because when trying to connect to a page, say FB, the screen would start blank, and the progress bar would freeze at the halfway point. Eventually, if I waited long enough, the page would finally load. Sometimes though (rarely), the phone works relatively normally, with clear voice and speed similar to my other Samsung phones.
My Orbi network is set up with fast roaming and daisy chain enabled. I have run tests with the phone in close proximity to several of the satellites, with the fastest connection being obtained when close to the satellite connected to the phone. Moving around the house, the phone does not switch to the closest satellite. Well, maybe it does if I would wait long enough.
I have run speed tests with the A54 located next to my old J727 and a Samsung A71. Sometimes, but very rarely the A54 will run slightly faster, but generally the A54 will show less than 5Mbps, while, at the same time, the other phones will be anywhere from 30 - 60Mbps.
Recently, I checked the starlink network speed close to the Starling router, it was 167Mbps. I immediately switch networks to the Orbi router, which showed the A54 as the connected device, and ran the test again, but got only 2Mbps.
In town, I ran the same test using the Puretalk (AT&T) cellular connection, and got 87Mbps.
I have no idea why the phone discriminates against the Orbi network, and it's difficult to argue with Samsung when they have tested the phone and found nothing wrong, instead claiming that the Mesh network is to blame, and asking me if I set up the network, as if to insinuate that I made a setup error. My answer to them is, as you wrote, that the phone connection was fine before the One UI update, but then, after updating, the problems started, so it has to be the update.
I've also told them that, to troubleshoot the problem, it would have to be done in my home where the problem exists. But, they will only do that if I pay for the home visit.
- CrimpOnMar 20, 2024Guru - Experienced User
Is there a way to factory reset the A54?
I run an app called GSam Battery Monitor Pro on my Android which displays the usage of each application. (Maybe your newer phone does this without an 'app'?)
- PaulR1975Mar 20, 2024Aspirant
Yes.
Settings, About Phone, Reset, Factory Data Reset.It has a battery setting which shows battery activity and in each app it includes system resource usage and wireless communication (mobile data in packets, wifi also in packets, GPS and Bluetooth scanning) but I don't know how that helps.
Phone is not one of the apps listed though.- CrimpOnMar 20, 2024Guru - Experienced User
Well, darn. My phone nags me to do a "reset" once a month. Had hoped a restart might make the phone behave better. Or, that the resource usage would reveal some "oh, my" app that was going wild.
