Gadadad
Feb 03, 2021Aspirant
Orbi RBR10 internet is unavailable
My Orbi RBR10 is coming up with the "internet is unavailable" message. I tried power cycling the modem, restarting the orbi, using a different ethernet cord and a few other things that similar thread...
Feb 03, 2021Guru - Experienced User
are you going
Modem---switch-----router?
thats what your description sounds like.
If so,
connect it modem----orbi----switch.
connect it like that then power everything off and power up modem, give it 2 minutes, then power up the orbi, then the switch
Gadadad
Just tried that and now nothing through the switch has an internet connection. The Orbi seems to be blocking connection to anything that runs through it.
- vajimFeb 03, 2021Master
Gadadad wrote:
Just tried that and now nothing through the switch has an internet connection. The Orbi seems to be blocking connection to anything that runs through it.put the switch aside and try it with just the modem
- GadadadFeb 03, 2021AspirantModem seems to be working fine. A ditect ethernet connection from that to my computer provides good connection to internet. No issues I can tell. What details would you like about it?
- GadadadFeb 03, 2021AspirantWith just the orbi and the modem it is giving the internet is unavailable message.
- plemansFeb 03, 2021Guru - Experienced User
what actual modem is it?
