JodiKAZ
Mar 17, 2021Guide
Orbi RBR10 router loses Internet connection repeatedly. Multiple re-boots needed.
My Orbi RBR 10 router with three satellites keeps losing Internet connectivity. I contacted my ISP and found that our Internet service has had no interuptions in the past two weeks. I tested the ISP ...
JodiKAZ
Mar 17, 2021Guide
The modem, as I call it, is supplied by the ISP to work with their setup. It is called a "POE Injector" and that is all the info I have on it.
Yes I tried just the Orbi router with no satellites. No good.
I don't have any wired devices. All run on wifi because there is only one outgoing port on the POE Injector, which goes to the Orbi router. However, to test I have disconnected the Orbi router from the POE Injector (modem) and connected directly to a laptop which then has Internet access.
Orbi Firmware version v2.6.2.104. Same version is on the router and all satellites.
Home is 2300 sqft and walls are wood frame with drywall.
Mar 17, 2021Guru - Experienced User
A POE injector connects a POE (power over ethernet) device to your network and supplies it with power. .
Whats on the other end of the POE injector?
That'd be the key.
- JodiKAZMar 17, 2021Guide
Other end of the injector is a roof mounted receiver. Looks like a small square satellite dish sort of.
When the system was installed the tech was glad we had an Orbi system, he said it removed the need for an additional modem as the POE would work directly connected to the Orbi router. Which it has for several months with no issues until now.
Thank you for the definition of a POE which was nowhere to be found on my "troubleshooting" info from my ISP.
- plemansMar 17, 2021Guru - Experienced User
Who's your isp?
If you connect the orbi to it in acccess point mode, does it work?
I don't know how to do an access point mode?
My ISP provider is a local company. BOLT Internet. We're rural and have no cable or fiber optic option, and only very poor DSL through a different provider.
