JodiKAZ
Mar 17, 2021Guide
Orbi RBR10 router loses Internet connection repeatedly. Multiple re-boots needed.
My Orbi RBR 10 router with three satellites keeps losing Internet connectivity. I contacted my ISP and found that our Internet service has had no interuptions in the past two weeks. I tested the ISP ...
JodiKAZ
Mar 17, 2021Guide
Other end of the injector is a roof mounted receiver. Looks like a small square satellite dish sort of.
When the system was installed the tech was glad we had an Orbi system, he said it removed the need for an additional modem as the POE would work directly connected to the Orbi router. Which it has for several months with no issues until now.
Thank you for the definition of a POE which was nowhere to be found on my "troubleshooting" info from my ISP.
Mar 17, 2021Guru - Experienced User
Who's your isp?
If you connect the orbi to it in acccess point mode, does it work?
- JodiKAZMar 17, 2021Guide
I don't know how to do an access point mode?
My ISP provider is a local company. BOLT Internet. We're rural and have no cable or fiber optic option, and only very poor DSL through a different provider.
- plemansMar 17, 2021Guru - Experienced User
an easy thing to try first.
Do you have an old switch sitting around?
If so, connect that to the poe and then connect 2 devices to the switch. if they both work, the access point mode might be a viable option.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
