JodiKAZ
Mar 17, 2021Guide
Orbi RBR10 router loses Internet connection repeatedly. Multiple re-boots needed.
My Orbi RBR 10 router with three satellites keeps losing Internet connectivity. I contacted my ISP and found that our Internet service has had no interuptions in the past two weeks. I tested the ISP ...
Mar 17, 2021Guru - Experienced User
Who's your isp?
If you connect the orbi to it in acccess point mode, does it work?
JodiKAZ
Mar 17, 2021Guide
I don't know how to do an access point mode?
My ISP provider is a local company. BOLT Internet. We're rural and have no cable or fiber optic option, and only very poor DSL through a different provider.
- plemansMar 17, 2021Guru - Experienced User
an easy thing to try first.
Do you have an old switch sitting around?
If so, connect that to the poe and then connect 2 devices to the switch. if they both work, the access point mode might be a viable option.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
