YumanAndy
Mar 25, 2024Aspirant
Orbi RBR10 Router Wifi
We just set up a RBR10 system last fall, my question is, is there a way that I can point a device so it only connects thru the RBR10 and not one of the satellites? Problem im having is I work at hom...
KevinLiT
Mar 26, 2024NETGEAR Moderator
Hello YumanAndy ,
Welcome to the NETGEAR Commuinty!
I understand that you are having issues with voice through your satellite when your Roku is streaming. One way that users were able to resolve issues in regards to voice via internet (which is also known as VOIP) is to disable the SIP ALG settings on your router.
To Disable SIG ALG please follow the steps below:
- Login to your Orbi admin page.
- Select the " ADVANCED" Tab.
- Select Setup.
- Select "WAN Setup.
- Check "Disable SIP ALG"
- Then Select "APPLY"
Best,
Kevin
Community Team
